B&K ST-202 musical-design MODS
I know this post was months ago, but I modded my ST-202+ and had subjectively good results. First, you need to know what version you have. If early 90's, it likely is the version with the DC servo circuit, which is the same as mine. Look on https://www.hifiengine.com for the correct schematic.
Changes I did are as follows:
1. Bypass main caps with 10 uF PP caps. I drilled holes in CB and soldered them in. If the main cap ESR is high, they should be replaced. You can also add capacitance, but would not go crazy as it will put more stress on the diode bridge. The original main caps have a huge +75% tolerance. I would not go over 150% rated capacitance just to be safe (23,400 uF) and bypass with the PP cap.
2. Replace 100uF electrolytic caps on input to 150-220 uF. I used Panasonic FC. Use caps that have the same diameter/lead spacing to keep leads as short as possible and allow the cap to sit flat on the CB.
3. Replace 25uF non-polar electrolytics. I used Nichicon Muse ES.
4. Added 33.2k resistor per revised B&K schematic. Don't know the reason for the change, but my version did not have it, so I added.
The above should get your amp to better than new. I modded further just because.
5. I changed out all the polyester coupling caps to PP caps (Vishay), but I don't know if this was necessary. I did notice that the original designer Steve Kaizer used PP coupling caps in more recent designs, so why not. The Vishay caps were also a bit larger and fit the CB better resulting in shorter leads. The Vishay caps were also made in the US which is fringe benefit, at least to me.
6. I also changed all the carbon resistors to metal film. This probably does nothing to the sound, as the resistors in the signal path are already metal films, but it can't hurt reliability and it looks cool.
After the changes, I noticed a few things. A quieter noise floor. A bit more heft to the bass. A bit more clarify. A success in my book.
Later, I may upgrade the ceramic wirewound resistors to a better wirewound. Again, I don't know if there is benefit, but I hate the fact that the white ceramic resistors have developed mold on them when the amp was just sitting around for years.
