Noisy 405
My QUAD 405-1 sounds great but when I measured the distortion there is a lot of noise on both channels. What is the cause?
Looks like mains hum with lots of harmonics rather than noise. Crosstalk from the mains rectifier current to the signal path maybe?
For example, if you changed the wiring such that the ground current between mains transformer and supply capacitors has a common section with the ground of the signal inputs or outputs, the spiky charging current waveform will be superimposed on the signal and cause lots of mains harmonics to appear.
Nope, can’t hear a hum. I think one of you two told me my grounds were not well laid out. My speaker returns are going to 0v and I need to move them to case. Then only a trans to 0v and 0v to case, like it was originally.
Speaker returns should go to the power supply's main capacitors common connection point,
not to the case. That is where the speaker current goes, and the path should be direct.
Then I wouldn't worry... really 🙂
Its true that speaker grounding needs to be correct but that is also as much for best distortion as well as hum. There are various easy tests you can do but if its silent hum wise and you are enjoying as it is then I would leave it be rather than go down the rabbit hole chasing things.
I
I would doubt the transformer (or caps) are a problem. Shared PSU's are always susceptible to interactions.
For example if you set one channel of the amp up to deliver lets say 10 volts peak to peak output @ 1kHz (no load) and have the other channel input shorted at the input socket then you should see no output from the that channel.
Now apply a low load of 4 to 8 ohms. If the shorted channel now shows an output (when the other channel is under load) then that is because of grounding interaction between the channels caused by where you have returned the speaker grounds to.
