active 3way I'm getting drivers for ...Scanspeak d2905/9500-Morel TSCM634-Scanspeak 32W/4878T..questions
I have the tweeters already & would like to use them. I want this a complete sealed system & modular top & bottom as easier for me to handle because of injuries. I am to use Hypex FA503 on each speaker set or Hypex FA253 bridged for tops & FA501 for bottom cabs. I have a dialed active dsp 3way system now & want to see if I can better it with DIY for fun. My questions are do you think these are good choice of drivers for the build.? I have looked at many drivers...I thought to go Purifi mid, but have always wanted to try a morel mid & I suspect it is good. Ill be using a NAD C658C & I have an Elysia parametric in system at all times, but can & most likely will be bypassed when switching to these speakers & using DSP parametric EQ via DIRAC. The SS bass driver was the tough choice but seems like it will do sealed & be clean to 300-375hz easy. If there is something major I'm missing or a better driver to use,please let me know. My listening position is 9' & listen to about everything you can think of via Vinyl & digital streaming .
Joe
