Hi, I have 4 pc’s. Fostex 6301b, which I am very happy with.
Now I want to use them in my 7.2 surround amplifier.
BUT: How do I Connect them to my receiver? There are only loudspeaker output for all the speakers. Front L+R, Center and subwoofer are without Amplifier, so there is no problem. I Can of course modifie the recieve and take the signal “before” it end in the poweramp. But it is a heavy job.
Is there a better solution which is easier.??
Thank you
Rgds
Lars Helsboel
Denmark
Thank you
Rgds
Lars Helsboel
Denmark
https://www.fostexinternational.com/docs/archive_products/6301B_Series.shtml
Hi-end multimedia speakers? I won103 i expect. That little driver has been everywhere.
If you are using them with speaker output to drive them, there may be some detail needed i am unaware of, but it should only mean that you are adding the shortcomings of your HT amp to the sonics. The high impedance of the Fostex input should be sufficient to drop the output designed for much lower impedance.
I have some plat eamps that have such an input, i do not know whether there is extra circuitry (ie some Rs i expect).
dave[/img]
dave[/img]
