For Sale Two large SLOB cabinets
Things you have for sale.
SOLD
They are not really for sale, they are for free - unless you want the blue pro series flightcase wheels also. then those will be 400DKK, I might also throw in the 8 connectors then.
The connectors and units are not included, it's cabinets only.
It is (needless to say) collect only. (Denmark, middle of Jutland)
These are built for 4x Faital Pro 15PR400's each, but many other 15" drivers will fit as long as they are not overly deep.
With the relative low Q (recommended) Faital's they will lower the Fs to 16Hz.
They weigh 90Kg each w.o. drivers.
Made of 26mm Oak, and everything else in black MDF (semi HDF)
The centerpiece is milled from 100mm black MDF, with an arrowhead center shape / curved backwall - to somewhat flatten the typical slot resonance peak. It works - but filtering is ofcourse still needed.
Rear chambers are covered in bitumen with foam on top.
Corners and centers are triangulated /enforced - all joints are miter joints.
The concept is surprisingly neighbour friendly, not at all transferring energy as std. boom boxes.
But they are great for locating loose rattling items on your walls or in the corners of your room 😊
The OB's w. the ESS' AMT's and amps are just included for scale
Thank you both for the kind words!
The dimensions are:
Width: 605mm
Depth. 635mm
Height: 890mm
Height with wheels: 101cm
Yes the OB's are also with the 15" Faitals' just the 4 ohm version, 8ohms versions used in the SLOB's/Ripoles
Sorry for the slow reply, I do not have any cad drawings
It is mere sketches and certainly the dimensions listed, part of the reason for the slow reply is that I wanted to check in the archive - but I'm yet to trace the design notes 😆
