Up for sale vintage LED VU meter from legendary BEAG, EAG/Telefunken mixing consoles.
Pure analog circuit with 33 LEDs, indication range from -60dB to +5dB in analog domain, or percents.
Device circuit accept balanced signals, also can be used with non-balanced lines.
Setup include original power supply unit (PSU), bipolar +/-12V, 2A.
Type of VU meter : MAK113
Size:
Tallness, indication panel - 243mm, circuit container incl connector +140mm, overall incl connector - 375mm.
Wide - 50mm, Deepness, max 120mm
Type of PSU: THE143, 220-230VAC,
Size: W200mm, H120mm, D160mm (incl connector/heatsink)
Overall, setup in excellent condition, only non-smoking studio use, and looks gorgeously.
Circuits of both modules (with "M" letter though but OK):
VU Meter
Power Supply Unit PSU
Initially, rig offered with 3 native connectors, with temporarily harness for inputs and PSU, however harness can be performed based on your wishes, for add fees.
Price - 230,-eur
Item will be packed carefully with international tracking across all distance.
FREE shipping across EU/UK.
See also my other items, small items can be added into box:
Few different items - Meters, Caps, Cam, Cable
Set of 4 excellent UTC transformers A-22, Northern Electric
Size:
VU Meter
Price - 230,-eur
- UTC 4x A-22 transformers, NE 5:1
- Canare L-4ES6 pro mic cable, Japan, 4 wires instead 2 to supress all noises, uniq offer - 9 colors
- Celestion G12T-100, guitar loudspeaker, 100W 16 Ohm
- Triplet ultra rare 4.5 inch meter
- never used big Simpson 4 1/2 inch meters with relay needles
- vintage detented/non-detented attenuators Daven, USA
- mains distiributor Tripplite, rack 19 inch, for USA 120V plugs
- Web Cam for Sony Bravia TV set
