Due to some changes at home, I have absolutely no space for them and that's the why I have to sell the best (and biggest) speakers I have ever had.
To simplify things, I'm selling all the drivers (unless 18" woofers) and all the original populated crossovers (TL1 or TL2 crossovers can be choosen).
All the things to be sold were bought brand new and they have no more than 100 hours of use. In fact maybe less that 70 hours.
I'm sorry but I cannot split anything not share crosover schemas or values. Please, do not ask.
For sale:
2x Fostek FT96H Super Tweeter
2x 18 Sound compression driver NSD1095N 8 Ohm
2x 18 Sound horn XT1086
2x 18 Sound midrange driver 10NMBA520
Crossover for Super tweeter+tweeter section. Original Values
Crosover for midrange section. Original Values
Crossover for Bass section. Original values but no LCR equalisation circuit for 18" woofer (not needed)
Crossovers were built with original values and fits Jantzen audio components:
Z-Superior Caps for Tweeter and super tweeter, cross cap at the begining of midrange and Z-Standard for every other cap in the crossover.
For bass section Elko Superior were choosen.
All the coils are oversized air core coils unless iron cored with discs 1,4mm at woofer low pass.
I'm asking 2300€ for the whole lot.
I can include, a pair of FaitalPro 18F510H 18" woofers that will work like a direct replace for BMS 18N862 woofers for 250€
PP fees if apply and shiping is not included.
Some pictures:
For sale:
Some pictures:
Hi Raelman
The fourth photo shows 2 caps and a coil in a box.
What are the devices in each corner of the box?
Good luck with the sale
Many thanks
-Edward
Many thanks
-Edward
Hello raelman,
Can u initiate a private message to discuss? Too new in here and not sure if I can start a private message
You have PMHello raelman,
If you mean 2 whit and 1 bleach plastic rectangle with screws they are electric terminal blocks for joining the wires.Hi Raelman
Many thanks
-Edward
If you mean the four gray tips they are the closing section of an isolated box.
I didn’t built a separated chamber as Troels did to give more ligers to the box and I used a plastic isolated box (IP65 electrical isolation box) to isolate the crossover from the air moving inside the bass compartment.
Yes, it was the plastic isolated box which caught my eye.
Your reply answers my questions and is much appreciated
Thank you
-Edward
Thank you
-Edward
