I just managed to get hold of a nakamichi dac101 12v for cars upon powerup into my home setup was quite suprised possible better than my own dac then music kind of skipped a couple of times and Silence????? dac has to led 48khz and 44.1khs it initially locked onto 44.1 and illuminated led now it flashes if you leave dac down powered for 2hrs it works for half an hour? I think its is a problem with clocks?? not v experienced in dig any one got any ideas???
by the way ps is 13.8 big fully charged lead acid😡
Sorry, no idea of the faults.
That is some piece of kit you have there. Dual tda1541a s1's possibly in differential mode.
http://park8.wakwak.com/~hilo/audio/dac101mod/
http://park8.wakwak.com/~hilo/audio/openit/da101/da101.htm
If i earned more £ I would buy this ebay one. Shame!
http://cgi.ebay.co.uk/NAKAMICHI-DAC...5840134604QQcategoryZ3289QQrdZ1QQcmdZViewItem
Kind regards,
Ashley.
Kind regards,
Ashley.
dbdell said:if you leave dac down powered for 2hrs it works for half an hour?
I think there is a problem with a part that gets hot. Probably a bad soldering somewhere. Check the soldering of all parts, start with the one's that get hot (powersupply stuff). happens a lot.
I have one also. It does not like 48hz, will buzz and lock up. With a 12v 12ah battery it will last about an hour. With direct current from adapter and a 44.1hz feed, no problems. It has a 3 amp fuse, shouldn't it last longer?
Does anybody have more information about this beast ? Schematics or service manual ?
I have found one off eBay and it seems well built but for the moment, lacking sufficient technical info, I am reluctant to dismantle or mod it.
The only schematic I found is partial and contains only a drawing for the output stage.
Anyone got schematic or service manual for older Nakamichi CDC101 (Car CD changer) and Nakamichi DAC101?
You find the service manual for the DAC-101 in this place. Vintage Audio Manuals - Your All-In-One place to shop for Vintage Audio Owner's Manuals, Service Manuals, Schematic Diagrams and Brochures . They sell manuals in extreme well quality.
I am also looking for a service manual, the DAC 101 has a huge potential since it implements two real S1 Silver Crowns TAD1541A... can anybody help? Neither of the online service manuals repositories has it.
Hello
here is the review and mod of nakamichi dac 101...
THE ORRONOCO AUDIO DIY: Nakamichi DAC-101 The Hi-end Dual TDA1541 S1 DAC
thanks
thanks
- Digital Line Level
- Nakamichi Dac 101??
