A few amplifiers from the warehouse,Do you have the circuit diagram of Audison SR4/LRX5.1K/lRX6.9? I'd love to pay for it😁
Audison SR4,TL494 is not powered
LRX5.1K,Turn on the fault light,The triode is not damaged
LRx6.9,There are several channels with low sound, it is suspected that the preamp is faulty, and it is inquiring
I am willing to pay for it
Maybe some of these will be close enough to be helpful:
https://elektrotanya.com/showresult?what=audison&kategoria=&kat2=all
LRX 5.1k remove the drive board for the sub channel, and check if its working.
If its working, check the diodes in the path to the output fets, and replace them.
Turn on the fault light, the transistor is not damaged. This situation is mostly caused by the aging of surface mount electrolytic capacitors on the protection detection circuit. Pay attention to the surface mount electrolytic capacitors on the detection circuit around TL494
