I mentioned in another thread about this as a side not but figured I'd post an actual thread in solid state.
I recently completed a lm60 build. I've cleaned up the wiring some from the one picture. Ive been running it for over a week and am quite happy with the sound. It replaced a SE tube amp using 6L6GC tubes. It has a nice full sound with warmth but still plenty of detail. The transistors don't even get warm on those heatsinks.
Hello invaderzim,
I purchased a pair of LM60 boards recently. I wonder if you have a picture showing the center tap ground wire where it attaches to the board. Does it go just to the right of c12?
For the record, I'm using the Ampslab power supply. You supply looks more robust. Regards, Bill
