Quick question about this 5V heater transformer HV isolation
I need to heat a 5U4G but I don't have a 5V winding, so will need a small separate 5V filament xformer. Would these Triad flatpack dual 5V secondary transformers have enough isolation for the HV?
https://www.farnell.com/datasheets/2279132.pdf
5U4G wants 3 Amps, this little xformer can do 4.8 A @ 5V with dual secondaries in parallel. So the current is covered, I just need confirmation that the HV will be ok here. Is the "hipot test" the measurement I'd be interested in to determine the safety factor one needs in a 5U4 rectifying 280-0-280.
Thanks, Ill get it. The four windings are on separate bobbins with these so there is that level of separation too. And they are easy to fit somewhere. Hammond makes the identical line of transformers too, Triad seems to be having a little supply chain issue;
Let us know how it works out. BTW, if you do need to knock down the voltage, put a resistor in the primary, not the secondary. The resistor value will be easier to find (not sub-one-Ohm), and the transformer won't be passing power that just gets wasted in a secondary resistor.
Reactions: stevenrotterdam
Wow thanks, more often we see people trimming the secondary, but it makes perfect sense to do it on the primary. My home always seems to be 123V occasionally dipping to 122 rarely going lower than that or more than 123.5. When I light up the 5U4 I'll see how much over 5V it settles at and adjust the primary.
