Ampli Sony TA F35
bonjour, moi aussi j'ai le son coupé quelques secondes après l'allumage. J'ai remarqué que le condo C312 avait explosé (voir photo)
J'ai l'impression que l'opération va être compliquée à réaliser, avez-vous des recommandations à me faire, et pouvez-vous me confirmer par la photo que c'est bien le C312 qui est HS, et que c'est bien un condo de 10 mf de 50 v. Avez-vous une Réf à me donner pour commander ce condo?
Merci de votre aide
TRANSLATION said:
hello, I too have the sound cut off a few seconds after switching on. I noticed that the C312 condo had exploded (see photo)
I have the impression that the operation is going to be complicated to perform, do you have any recommendations for me, and can you confirm by the photo that it is indeed the C312 which is HS, and that it is well a condo of 10 mf of 50 v. Do you have a Ref to give me to order this condo?
Thank you for your help
:cop: Ceci est un forum en Anglais
In the US you can get a good replacement for that capacitor from Mouser or DigiKey. Not sure what are good sources where you are. There were a couple of shops I would buy parts from in Brussels when I lived there. One in Jette and one in Anderlecht. A Nichicon audio grade 105 degree cap should be good. Or a Panasonic or Matsushita one. However the cap might have blown up because something is wrong with that 45.8V supply.
