Unusual question about Naim amps lack of output inductor
Hi there
People may have seen news of recent devastating flooding along Australia’s east coast.
I am helping family and friends try to get some music happening to cheer them up and one home has multiple speakers running from the autoformer shown in the photo.
Electronics were flooded and destroyed. I have loaners but the only amp that will easily fit is a Naim Nait or NAC90 which as standard for Naim need long Naim cables because they have no output inductor.
My question is will the autoformer provide this missing inductance?
Thanks, sp
The inductance required is tiny and so I wouldn't use what you show there.
You could just use a 0.47 ohm resistor in series with the positive speaker lead which should provide enough isolation from a possible capacitive loading. Place the resistor at the amp terminal end of the wire.
(It never ceases to amaze me why so called high end gear has such basic design flaws 🙂)
A smart Naimaholic would be aware that Naim (NACA4) cables were actually a standard, economy type of PVC sleeved, heavy gauge twinflex - the kind you could buy as one of several varieties of commercial speaker or DC power leads etc, for a much cheaper price if you checked the supplier catalogs.
Check the specs: https://community.naimaudio.com/t/naca4-versus-naca5-speaker-cable/3972
These don't include conductor centre spacing but a careful measurement of original leads with verniers should help because attempting to match capacitance and inductance values will prove too difficult and time consuming.
You may not find this exact spec today but facts boil down to it being multistrand flex. copper wire with a certain CSA of copper and centre spacing and I've occasionally found cheap Asian product in electronic parts stores that fits the bill admirably. It's usually clear rather than black but as expected, it doesn't make any discernible difference.
Reactions: gwmorgan
Hi there
Thanks, sp
Good day
Information from old Naim forum about cables
FOR INFO THE RELEVANT SPECS ARE:
1.3 - 1.5microHenries per metre (Loop)
MAX 20picoFarads per metre About 25milliOhms per meter (loop)
MIN Length 3 metres
Here's a Nelson Pass amplifier with a whole lot of feedback, and no inductor.
Thats still a 'low' feedback design. Nothing wrong with that approach if that’s your philosophy, but you have to accept that there’s no magic here. Either there is sufficient phase margin at HF with a capacitive load or there isn’t and the loop gain has to be tailored to suit. The other option is a low value resistor in series with the output - IIRC some of the earlier Naim amps did this. Looks like that’s also the case in Mooly’s post #18 if I’m reading it correctly with R647 and 648 - but strange that the Al’s are not damped with a parallel R and that the Zobel is after the L.
All amp (feedback and non- feedback, with or without output L) outputs ring when driving a capacitive load.
