TKD 2CP2500 / 2CP2511 / 4CP2500 Pot Question
I've used these pots for a number of years in various projects, in both 2CP2500 and 2CP2511 guise.
I now need a Quad pot for a project and the 4CP2511 fits the bill mechanically. However, I can only get it in a Log guise and I need Linear. A quad log is £129 here in the UK, so it's not a cheap part.
I happen to have some spare 2CP2500 Lin Dual pots (I bought them here in 2020, 50KB type with PCB pins). I am thinking that it should be easy to swap the tracks from the Lin pots into the 4CP quads, no? Why wouldn't it be? I have taken the 2CP2500 apart before. Unlike the Alps pots, it's easy to disassemble. I cannot see any reason why TKD would depart from the mechanical specs for tracking between Dual / Quad, so this ought to be an easy exercise, right?
Am I missing anything here? Why would the mechanicals of the tracks / pins differ? I'd like to be sure before dropping £129 on a part that I won't be able to return.
Thanks,
Thank you, Ray. That is good advice.
The Lin pots I have are the older ones, but the quads I see on HFC's site are newer type. I have a selection of green (older) and black (newer) duals here on the shelf, so I will have to take a couple apart and see.
