Something never discussed about schottky diode
The "knee" of the curve, where it bends upwards and "excess noise" begins to appear, seems to be about 300 Hertz. How well do your PSUs reject noise below 300 Hertz?
_
Another thing about Schottky diodes is the reverse leakage current. I was using some of the diodes to protect a couple inputs on an Arduino from overvoltage when the Arduino was powered off (inputs clamped not to go above Vdd). With one type of Schottky when the Arduino was powered on, the clamped inputs were immediately destroyed. Apparently the reverse leakage current caused overvoltage at the inputs before the rest of chip fully powered up. A different type of Schottky worked fine. Also, found that a DVM in diode check mode showed evidence of reverse leakage current in the problematic Schottkys.
