30+30W on 8Ohm for everyday listening
I would like to ask you a suggestion on a class D amp capable of 30+30 Wrms on 8 Ohm for everyday listening, with RCA and Bluetooth inputs. No eq or similar, just the volume. Possibly already in its case.
I’ll buy a separate AC-DC power supply.
Budget for the power amp only is 80 € approximately.
I will connect two full-range speakers FHXL with Mark Audio 11MS and they will be used for music and sometimes tv/movies.
Thank you,
Roberto
