Doubler PS sanity check
Good day,
I have some 120VAC transformers I would like to put to good use. I need about +260V at circa 140mA, and -260V at circa 20mA. Doubling the 120VAC will do the job easily, but is it possible to also extract the -260V from it? One solution I came up with is shown in the schematic (done in multisim) + simulated output. C1 and C2 are 200V caps, C3...C6 are 450V.
what do you think? Any suggestions for improvements?
many thanks,
Erik
Looking back at my schematic, you can see that at the junction of the two 200V (doubler) caps the voltage is DC with a bit of ripple (look at the green line in the voltage graph). At the other hand of the transformer winding there is the 120Vrms swing, which is "sent" to the lower two diodes through C3.
So I do not think your schematic will work?
Just build it on a prototype board, Still have to add some load resistors. Testing will be done whenever I have time! Variac and goggles are my friends!
I was able to test the PS, drawing circa 70mA from the +250V and 18mA from the -250V (about half of the target current). It worked nicely, voltage drop in line with the calculated reactance of the cap. So I am happy. For anyone else reading: the voltage of the negative rail can be significantly reduced with a smaller C3 cap (higher reactance at mains frequency). This is recommended only when drawing a (relatively) constant current is needed from the negative rail.
Of course always willing to prevent exploding caps, so, what you recommend would be something like this? The positive side of this PS could be nicely wired P2P with an inline diode bridge.
