One or two power supplies for an HeadAmp?
Does using two power supplies, one for each channel, improve sound perceptionthe improvement quality or not?
In the case of power supplies with +/- I could say that something has improved. Not in the case of the power supply only with +.
Edit: the correct term is quality improvement
"improve sound perception"
Is kind of subjective , even if you can measure differences.
For a poweramp which usually has unregulated power supply , I would use seperate transformers. For a HP amp I chose a compromise . 1 transformer and rectifier , but after the mosfet on/off switches , L & R get their own CRC and regulators. Whether that really improves sound perception is a good question but it can't hurt and stays affordable.
You can improve your amp by:
1. Separate linear regulator. Left and right amp supply doesn't interfere each other.
2. Mod the amp output to RCA female and HP to RCA male. Not sharing the same ground pin from 3.5mm or 1/4 inch.
No. 2 have more improvement than no. 1.
Reactions: Whitigir
