Hi
Somebody brought this amp to me saying that it is totally dead. Upon checking I realise that it is using a "ICEpower 125AX2" module, a class D power amp combined with the SMPS. I injected a signal directly to the power amp and it is working. There is no power to the preamp board. There is a 3 wire cable coming from the module to the preamp board and it connects to the 7915 and 7815 fixed regulators. There is totally no voltage on these wires. I guess if I can provide the +15 and -15 volts to the preamp, then the amp will work. I cannot source the schematic for the module, only the preamp schematic can be downloaded (attached). The module is a smd board and looks very complicated to me. Instead I was thinking about providing a separate +15vand -15v just for the preamp. Will this work and will it cause any interference to the SMPS. Please advice.
Hi, if the power supply +15 -15 have disappeared ... the preamp may have a problem.
you can try with a separate power supply, as you thought
Maybe the regulators or preamp itself are shorted, so they pull down the ICE module built-in +/-25V auxiliary power supply.
I would disconnect all wires leaving that ICE connector and check for +/-25V present straight at the connector.
If not present, yes, any external+/-15V supply will/should feed that Preamp.
Just in case add 10 to 47 ohm 1/4 w resistors in series with each rail, to act as current limiters or fuses IF the preamp is shorted.
