max output 90 to 35hz!
Hi, I need to have as much input as possible below 90Hz.
I have to use 4 subwoofers per side, I cannot carry big and heavy things (we will use the system in establishments with stairs, platforms, sand etc.)
These are my ideas:
1) I currently have 3 tham 15 mk2 per side, but they are not enough, I can build 2 more tham15 and get to 4 tham 15 per side
https://www.martinsson.cc/blog/images/THAM15MKII_BUILD.JPG
2) I have 8 turbosound tsw118 witheout driver (I don't know if the exact name, but it is the sub with the curve, ie identical to the lower part of the tms4) I could put the recommended PD cones with 4 "coil but many speak of poor efficiency at the bottom, Does this problem exist even in groups of 4?
https://i.ytimg.com/vi/OWuLN5mF_NE/maxresdefault.jpg
3) build tham 18
https://i.ytimg.com/vi/oisGNpC3M0A/hqdefault.jpg
4) build the new paraflex, but in compact versions. both from 15 and from 18
https://i.ytimg.com/vi/KRdBzvFJtY4/maxresdefault.jpg
5) recommend something suitable for the purpose 🙂
--- consider that the dimensions of a cerwin vega L36 are already too much: D ---
in short, which one makes more from 90 hz down, I don't need 20hz but an extended response up to 35 / 40hz pretty powerful!
I have already tried to ask but it creates a lot of confusion that top speakers use, etc etc ..
if you have simulations they are welcome!
thank you all!
