Mosconi AS 200.4
good day bros. I am repairing a Mosconi AS 400 4 channel amp. Need help. The problem is, when ever you turn on the amp an audible popping sound comes out in all the channels. There is no popping sound during playback, only when you turn it ON ,Even with out the RCA 's input connected to the amp. The popping sound is not really loud. The amp is only 4 months old. I measured the Vdc output, it is jumping to 0.6Vdc to 0.8Vdc when pop sounds come then goes back to 0.005Vdc again. I checked all components, but i can not find any fault. Before there was no popping , only after we had used the amp in long period of time at high volume after that the problem begin to come out. What maybe the cause of this sound. can it be eliminated?
