old 2SK1058 Hitachi vs ECW20N20 Exicon in a simple Circlotron
Here follow some simulations and measurements about the use of ECW20N20 instead of old 2SK1058.
Both are lateral type mosfet with negative temperature coefficient so these are stable without a compensation of Vgs.
As show in the simulation the output impedance with 2sk1058 is 1.36ohm and with ECW20N20 only 0.4ohm.
The distortion measurements are incredible because without feedback with only 2 mosfet we get 60W on 8ohm and 100W on 4ohm.
The main benefit of a Circlotron design is an high power amplifier with no switching output stage like a pure class A but higher efficiency, with only 1A bias current still have 1mA with 2.3A on 8 load (see last image).
The anodic voltage for the 6Z51 should be reduced to 140-150V.
Tell me if you find other lateral mosfet with the same performances.
Reactions: Haze Head
