bizarre woofer freq response? 0-1khz +/- 1db
hello , im puzzled by the freq response of my dual 6" bass drivers , wired in parallel , 3 way foorstander ( SD Acoustics 'SD5' , from 2001 )
drivers unknown, no labels , but seem to be giving an incredible in room response of +/- 1db 30-1khz, which seems bizarre ( well that seems incredible to me )
basically, im trying to lower the crossover point to 200hz , but i can not get the woofer to stop outputting , its pretty flat to 1khz ( I used a textbook filter of 6.7mh + 100uF 2nd order ) ....those values should produce approx a 200hz crossover with 4ohms
the drivers have combined DCR of 3.3R , plus 0.8R inductor DCR
please see the graphs , one taken 10cm away, with the above filter applied ( both 1/48 smoothing)
other graph is with no filter , taken 40cm away
- I dont understand how 6.7mH + 100uF can produce a crossover point at 1khz?
waterfall ( with filter ) ;
how am i able to get these woofers to crossover at 200hz?
PS: the original woofer xover used is 4.3mH + 60uF , which was giving a xover point of 800hz.... the midrange uses no xover, SD Acoustics call it ' semi active design ' (!) .... the midrange is flat to 200hz , so I dont understand why they crossed the bass at 800hz ?
my plan is to add a band-pass filter to the mid >200hz <3.5khz
the cabinets are made from a gravity cast resin , so are not wood, and are and heavy ( 32kg )
Its the setup. No need to reinstall.
thanks... ive disabled all audio card inputs on the PC , which REW recommend to avoid a feedback loop
i took a measurement with the mic disconnected ( but USB interface still connected ) , see graph. the 50hz spike must the the UK mains frequency.... im guessing the high freq. noise is electrical noise from the PC itself and/or USB interface
