Good evening! I'm replacing a faulty W02 bridge rectifier in my Quad 44. I currently have some W10 rectifiers on hand, would that work in the 44? The difference between them are the DC blocking, RMS and peak reverse voltage ratings, which are higher for the W10. I attached a schematic below. Thanks for any input!
Yes it will work fine. It's just a higher-rated part in the same package.
Thanks! Your posts in the past have been very helpful when I've been working with other Quad stuff.
