Power On Thump Noise Shut Down Pop Up Noise Remover Circuit For Tpa3116D2 Tpa3118D2
Hello Friends Today Iam Shareing Power On Thump Noise, Shutdown Pop-up Noise Remover Circuit For Tpa 3116D2, Tpa 3118D2 Class d Amplifier Chips. Its Works Very Well With Both Power Supply's Whether Its A Conventional Transformer Power Supply Or a Smps. Pop-up Sound Will Not Present In Power On/Off Times. When Using A Non-Regulated Power Supply Input Voltage Below 18vdc Q1 Transistor Try To Conduct Its Will Enable The Mute For Short Period ( Or a False Trigger ). I Will Drop The Schematics Here, All suggestions And Modifications From Group Member's Are Welcome. Recommended Voltage Ratings Are +18vdc To +24vdc (max). Circuit Can Power From Same Amplifier Power Supply. I Have Upload a Demo Working Video On Youtube For This. Watch Here
Anti Power On Thump Noise // Shut Down Pop Up Noise Remover Circuit For Tpa 3116D2 Tpa 3118D2 Chips - YouTube
Link For Schematics : Mute Circuit-1.pdf - Google Drive.
Hi Biju JP-San,
I simulated your idea.
It may work as expected.
The result is attached.
I also made another Uniti-Pop Curcuit.
The result also attached as below...
CyberPit
