Radio transmitter for subwoofer
Hello all,
Not sure if this is the right place, but. I have a question for you.
A friend of mine wants to install a subwoofer in a corner in to his living room; and knowing I'm "into such things" asked for my help in solving an issue.
His problem is that the hifi gears and loudspeakers are installed along a wall, while he would like to install the subwoofer on the opposite side of the living room, in a place 6-7 meters away from the amplifier.
His idea is to build a low pass active filter, connected to the amplifier outputs, and then route the filter output to a subwoofer amplifier; this is not a problem, both of us are quiet experts in electronics.
The problem is that there's no way to run a cable from the hifi gears to the subwoofer.
So, the only solution that came to our mind is to use some sort of audio radio transmitter/receiver.
So, do you know of any of such thing?
I can find a lot of TV audio repeaters, wireless headphones, and so on: but do you know a nice real solution, with (almost) zero delay, maybe an analog one, with a wide passband, that could transmit and reproduce the subwoofer low frequencies?
With h such a device, we could be able to install a subwoofer with an integrated amplifier, and only have to connect it to the radio receiver.
Thank you in advance.
Ciao,
Giovanni
