rockford punch 200dsm
he amplifier was purchased broken, one channel with dc output of 20v, 2 irf540 damaged, and lm833 damaged, I restored it, but not knowing if the old owner has touched the bias trimmers, I wanted to know if of service the values are in the normal.
Rockford has high bias specs (too high IMO) for their amps. The specified idle current for the 200DSM was 1.4A (attached). The 0.6A of idle current is much lower than what Rockford gave for this amp.
In many of their schematic diagrams, they specify 2mv across the 0.1 ohm source resistors. For large amps, that causes high current draw and excessive heating.
Running a sweep and confirming that there is no crossover/notch distortion is the definitive test for sufficient bias current (for me).
