Sundown SAE-1500D
Amp is producing rail and regulated voltages .
Amp has output but it’s very distorted like someone is farting through the test speaker .
Any idea on where to start looking since everything I’ve checked so far tests fine
I will have to get a new probe for my scope in the morning somce o believe it’s bad the scope doesn’t do anything at all I believe the probe went bad .
Here’s some more pics of the opamps and the transistor
I’m just wondering if it’s normal to have a square wave on the output terminals with no signal .
With just power ground remote hooked up I bet a square wave on the output terminals was wondering if that’s normal ?
Trying to track down the issue with this amp
