Hello
I am looking for some thoughts on an enclosure for the 7ms driver. I already have a pair of the drivers but am a bit stuck on a design.
Goals / criteria
- Under ~12" x ~12" footprint
- Room size is about 250 sqft
- Able to be very close to / up against the back wall
- Floor standing or bookshelf is ok
- Ideally used without a subwoofer
- FAST / WAW ok as long as a speaker level passive crossover can be used
- Driven from a 50-100 watt home theater type receiver
Any ideas on something that would meet the above?
Thanks!
Goals / criteria
Thanks!
Dear GLF,
This is the box for Alpair7MS, I'm using.
Alpair7MS YouTube movie.
Tapered Wave Tube with Damp Duct(TWTD)/ ダンプダクト付きテーパー波動管(開口部オフセット型TQWT) + Alpair7MS - YouTube
The Pencil for the 7MS is within your plan, and seems to work very well:
https://frugal-phile.com/boxlib/pensils/Pensil7MS-310818.pdf
I'd definitely consider using a sub or going WAW, depending on the music you listen to and listening volumes
