Where to buy genuine JRC5534DD?
Does anyone know somewhere that has stock of genuine JRC5534DD?
Mouser and Digikey etc are showing them as 'no longer manufactured'.
I should add that I'm not interested in 5534's produced by TI, On-semi, Philips or Signetics.
JRC is a wholly owned subsidiary of --Nisshinbo Holdings Inc which is also Japanese owned.
I was going to say try direct from Japan but it seems several Japanese audio chip manufacturers were recently burnt down .
This website is saying they sell---and quote --- " the JRC5534DD parts manufactured by JRC are available at"------
JRC5534DD JRC Integrated Circuits (ICs) - Jotrin Electronics
The company say -yes we are Chinese but a distributor and source our products (among them ) Japan ,it depends how much you believe that but otherwise you should look for a Japanese website selling old stock.
I have a lifetime supply of the NJM5534M, this is the DMP package on a very big reel. I’m not sure if it’s the ‘D’ grade, I have to check.
You will need a DIP adapter. The JRC DMP package is slightly wider than the more common 3.9mm narrow SOIC package so some of the SOIC-8 to DIP-8 adapters might not work if the SMD pads for the toe is not long enough.
PM me if you need more details.
I just checked, it’s not the ‘D’ grade.
If you can, put 5532 in the circuit, I think 34 is the1 channel version.
No, not pin compatible, 5534A is not unity-gain stable as it lacks internal compensation too - so not necessarily circuit compatible either.
Or AD797 for low noise...
The AD797 is very noisy if you're in a high impedance circuit, since it only has low voltage noise, not low current noise. Best used for source impedances of a 100 ohms or thereabouts such as MC phono amp or dynamic mic amp.
At >2k souce impedances the 5534A will outperform an AD797 (in noise and price).
<snip>
Mike, do you have found a good source?
The “D” suffix are exactly the same die as the none-“D”. The “D” are cherry-picked from the same NJM5534 wafer and has guaranteed noise performance.
IC testing adds to the cost of the product. A none-“D” grade in some cases can qualify as a “D” grade if only it was screened. Think of how 1%, 5% and 10% film capacitors are graded. Capacitor testing is far simpler than ICs but the general grading idea is the same.
A similar situation exists on MPU and MCU speed grading.
It IS true that the cherry-picked versions of the 5534 are quieter. But it is practically only a difference of about 1 db, and this would not be noticeable/audible in a line-level circuit; just barely audible for a phono, tape head or microphone circuit.
This would be much later (~20yr.). Someone here might remember who selected the Raytheon parts for noise and made up a part number of their own as an audio op-amp.
Analog Systems. It was the MA-332. I built a number of mic pre's with them back in the day and still have a few laying around. They were also widely used in test equipment. They were selected for more than just noise, though.
