Massive p3000.1
Hi guys I have a massive p3000.1 I had 5 shorted output fets. I have replaced all the output fets and the amp will play audio for about 5 min then it will start making loud pops and screeches and go into protect. I noticed after 5 minutes that the output inductor on board 1 is like 205f and board2 is at 105f. I swapped the inductors from board to board and board 1 still gets really hot. What should I check from here?
Picture of amp and revision stamp
Driver boards are typically small boards that connect into the main boards (the ones with the transformer, FETs...). This amp doesn't use a PS driver board. All PS components are on the main board.
The two large boards may be considered master and slave in some amps. This generally means that the master has some sort of influence on the slave. That's not really the case here. I'd like refer to them by stating which one has the RCA jacks and which one has the power terminals.
