Has anyone built this Headphone Amp kit from Graham Slee. The Novo.
DAK Novo Headphone Amplifier Kit - HiFi System Components
I think I’m going to get this kit and build it. Looks interesting. I’ll post again when I get the kit. Thanks
What is is with these kits and not having power switches? Maybe I am too snobby for this DIY thing, but I just don't understand it.
ACP+ is terrific sounding, not only as HPA, but as preamps too, if you do not need excessive gain. Not to mention its cap coupled, so quite safe with expensive headphones.
Whammy is another option. Probably easier to build. Boards and parts for both available.
I built this kit today in two hours and you would not believe that it really sounds very good.
Verify your identity
How can you go wrong for only 14.99
Ordered it about a week ago.
Don’t know why the link says verify your identity. It will take you to Walmart.
Is there another kit you would highly recommend? Thanks
Marsh HPA.
you get what you paid for...
Nevertheless, I built something like this a few years ago and it surprised me as well.I built this kit today in two hours and you would not believe that it really sounds very good.
It seems to be a 47. Design by Apheared. An improved CMOY mint-tin portable. If the parts are not crap, it does very well in high-Z phones and not bad in low-Z.
How to build the Apheared 47 Headphone Amplifier for Grado Headphones – Ben Feist
No, you never could build the Apheared for $15 even with a free case. That's Asian mass-production and low-bid contracting.
The Walmart page has an invisible-to-humans intermediate page. The DIYAudio server pokes the Walmart server for a page title, and gets the for-robots page and title. Happens a lot in this modern web (the forum server code is very old). You "can" manually edit the link in your posting, but few do.
Thanks for all the replies. Unfortunately, my amp is not working now. I posted in another thread: What Kills Wall Warts? and explained what may have happened to the amp.
Might as well explain here as well. The hpa kit did not come with a power supply and called for 12-18vdc, but no mention of the current needed. I just happened to have a 15vdc 400ma wall wart. Honestly, the amp was working great. I disconnected the power from the amp, I was just moving it around, it has no power switch. When I connected it again, there was a spark at the input power jack and also a very loud hum when I turned up the volume. I measured the voltage on the wall wart with a multimeter and it read 22vdc, not 15vdc. So, I’m assuming the wall wart went bad eventually because of insufficient current and may have already damaged the circuit. Any help or advice would be appreciated. Thanks.
The $ 14.99 amplifier is broken.
You can buy another ... It's cheap. Here you will find an easy to do, cheap and with much better results.
Could anyone help me with a little troubleshooting of my amp I recently built and have been talking about. The amp was working great and then out of nowhere, there is now a loud buzzing sound when I turn up the volume. I rechecked all of my solder connections and touched up a few of them, they all look good now, but still the buzzing. I can’t figure what may have happened, since the amp was working great.
Possibly the only variable that can change relatively short term is the supply voltage if it is a battery, if so, replace it.Could anyone help me with a little troubleshooting of my amp I recently built and have been talking about. The amp was working great and then out of nowhere, there is now a loud buzzing sound when I turn up the volume. I rechecked all of my solder connections and touched up a few of them, they all look good now, but still the buzzing. I can’t figure what may have happened, since the amp was working great.
Not using a battery, using a wall wart. First was a 15vdc at 400ma and now trying a 12vdc at 500ma. Still the loud buzz when turning up the volume. Don’t know what happened, it was working great, then all of a sudden a problem.
First, check all electrolytic capacitors. ESR, capacity, V-loss.
Then, you could have posted the diagram you received with this kit ****. No one wastes their time with such cheap things without clear details.
The fact that something is wrong does not mean that it has the same solution, regardless of the situation.
Ok, give more details about the power supply. Not all can ensure a proper ripple.
I would have to get a capacitance meter. Just have a regular digital multimeter right now. The directions called for the circuit to have 12-18vdc. I originally used a 15vdc 400ma wall wart. I’m assuming the wall wart went bad because it was measuring 22vdc not 15vdc.
- Headphone Systems
- Novo Headphone Amp Kit
