ARCAM Alpha One repair
Hi folks
My Arcam Alpha one CDP has stopped reading disks. With no disk in the machine it displays 'disk'. When a disk is inserted it spins it up and tried to read it, during this time it displays '01' then the display returns to 'disk' and it has failed to read the disk.
I'm wondering if I should replace all the electrolytic caps in the servo section?
Or is it much more likely that it is the laser that has failed?
Is there a procedure to potentially diagnose the issue?
The SM is particularly unhelpful and just says send it back to ARCAM for repair:
