There is a 'Brown Dog' adaptor, but I can't seem to find it on sale at any UK outlets. Has anyone got any other suggestions that might be easy to find in the UK?
Dual-to-Quad Op Amp Adapter - BrownDog Adapters - 070401
Thank you!
Thank you!
Don't know, but why do they never put pads for a HF decoupling cap on these adaptors? I'd be tempted to design a better PCB then people could order their own on OSHpark or whatever...
Hi Mark,
You are quite correct - it's something I've picked up on as well. If you opt for modern OAs, with their fast slew rates, it's a recipe for oscillation. However, I only need to try this in order to replace a couple of TL074s, as a proof of concept. If it works, I'll get the whole PCB revised for dual OAs.
I could probably do the whole thing dead-bug-style. The question would then be mechanical, i.e. whether I can keep the dead bugs shallow enough to go back into the item designed for 074s...
You are a total star, Mark! Thank you!
I do not have Eagle...but I can ask a friend for the gerbers.
Thank you again!
Thank you again!
I would say just double check the pin out is what you want, I assumed standard dual SOIC8 and picked a "quad opamp" pinout from Eagle without checking it against anything, but I know the power pins are 4,11 on most quads so I believed it!
- Design & Build
- Parts
- Dual to Quad Opamp Adaptor
