What is the best TPA3251 board currently available
Hello everyone,
I am looking to purchase a TPA3251 board from eBay/Ali. Which board would you recommend? I have read the last 100 pages of the thread titled "TPA3251d2" and all pages in the thread "Aiyima TPA3251 Modification Build Thread !", but could not find the definitive answer to which board is the best.
Unfortunately, 3e Audio does not appear to have any TPA3251 boards in stock, so I am looking at other implementations.
Here are some examples:
1. TPA3251 HIFI Digital Power Amplifier Board Dual Channel 175W+175W Class D Audio Amplificador For Home Theather|Amplifier| - AliExpress
2. TPA3251 two channel digital power amplifier board|Amplifier| - AliExpress
3. TPA3251D2 Digital Power Amplifier Board 175W+175W High end Stereo HiFi Audio Amplifer Class D DC24 36V|Operational Amplifier Chips| - AliExpress
Hi DrGenius,
1- I would choose the first one on your list. Daniboun has tested version 3255 of this PCB and finds it good.
2- The second link, a guy on the forum there tested, not bad but there is a slight hiss.
3- The third I would not touch, reminds me of a 3255 trash that I had.
Denis
Edit : For the second link, I'm wrong with the 3221, but same look
If you don't want fake/bad/unknown parts you can always choose an evaluation module from TI.
The EVM for the tpa3251 isn't cheap but it's a good amplifier that can be setup for se,BTL,pbtl. (4,2,1 channel)
If that's too expensive, I'd guess the tpa3220 micro evm is no slouch either. That's the one I'd be getting if I had to choose again.
Hi denbret. Thank you for looking at the links and giving your opinion on each board. I was leaning towards the first board as well. Well, actually I wanted the 3e Audio board, but that ship has sailed.
Thank you for the suggestions, joensd. I am sure that the TPA3251 evaluation module uses high quality components, but it seems too expensive at the moment. TPA3220 micro EVM, on the other hand, looks promising to me.
More than 3 years since the last post!!! 😎
