Prefer local sale, you can listen/test before buying:
1. Built by Min Yang at: Home one 6SN7/6SL7 tube preamp with separate power supply. Includes (2) 76 tubes, (4) 6SL7 tubes, (4) 6SN7 tubes, (1) Westinghouse rectifier Tube. This preamp has 6 inputs total, including one MC phono input. $1200
2. Unassembled Spud Amp kit. Includes (5) 6CL6 tubes and (5) 6197 tubes. $350
3. AR XA turntable with Jelco tonearm. $450
4. Hafler DH-200 amplifier and Quintessence Preamp. Prefer to sell both for $500
Pick up in Pasadena, CA
Here's some more gear available for pick up in Pasadena, CA:
1. Fisher KX-200. $700
2. 6L6 (Russian tubes) push-pull amplifier w/4 RCA 5881 spare tubes. $1100
3. AN Kit 1 300B amp with (2) extra 300B tubes, (5) extra 5687 tubes, (1) 6SN7 tube. $1500
4, RH universal SET amp with 6BG6A tubes (with adapters). This amp can use most 6L6 tubes, including 6L6 metal tubes. $500
Tektronix 575 curve tracer: $150
Hickok 580A tube tester: $100
B&K 707 Tube tester: $100
Agilent signal generator: $100
HP 711A power supply: $100
HP Oscilloscope: $100
I’m interested in the Hickok tube tester and oscilloscope. Are you available this weekend? Please PM me with contact info. Thanks!
