Sony ST-SA5ES Front End problem
Hello to all fellow members and friends. Sony ST-SA5ES tuner came to my hands with poor sensitivity issue and after a re-alignment seems to corrected but still signal strength reports low levels. Looking around front-end circuit, I realized that IF level is too low and not clean 10.7 MHz wave. Unfortunately, SONY doesn't provide schematics of this Front End can. Is anybody from you faced same problem or has this schematic in order to investigate deeper? The P/N is 1-693-289-11. Also it is not available any more in known market places. Maybe someone of you has this available for purchasing.
Thanks in advance for your kind attention and help.
John
JPaudio-- the Sony ST-SA5ES --original IS available at hi-fi engine --two versions - the original and the V1.1 are available .
I logged in and I am looking at the schematic .
Hi-Fi engine insist you personally log in that's why I got a -403 when trying to use the above link.
Thanks a lot for all they interested. I do have an account at hifiengine.com and I have both versions of schematics. But my units is NOT the ver 1.1 one. This is the reason I am looking for more info about Front End Tuner can. See attached photo.
Yes, schematics for my model version shows the front end as a line box only. No details of electronic circuit inside. And because of this I am looking for someone that had this sensitivity problem before.
John
I ran into the same problem - the Sony ST SA5ES tuner has low sensitivity, the dB indicator constantly changes from 21 to 36, the automatic station search does not work, the stereo does not work. By replacing the boards, I found out that the problem was with the Front end board. I changed the input Mosfet in it, but it didn't change the situation. Maybe the author of the topic can help me with advice.
P.S. LC72130 and quartz resonator changed - no success.
So you are certain the fault is within the frontend?
The most common fault I can think of would be duff trimmer capacitors. If one of the tuned RF circuits is way off, it's no wonder that the unit is deaf. (Check whether they can all be peaked up on the high end. If there is one that can't, that would be suspect.) Sometimes the caps in LC cans can corrode and go bad, too. You really need some better tools to diagnose issues like this, a signal generator with sweep function would be handy for one.
