Hi All,
I've visited & enjoyed this site a lot over the years but this is one of my first posts. Hoping I can seek some advice on output transistor selection.
I've inherited a Crown Macro Reference amp, Esoteric version with previous repairs & problems with one channel not working. The previous repairman replaced some (not all) of the original Crown C7065-3 & C7901-9 o/p's with MJ15022/23's & replaced 2 of 4 drivers with different parts as well. In addition, new emitter resistors for the MJ15022/23's with 10% instead of factory 5% units. Upon receiving the amp, I found one of the replacement drivers was not even soldered, yet the previous tech claimed it worked fine on the bench! I soldered the driver & the amp actually came to life! However the channel module is really is a dogs breakfast with 4 different o/p's, 4 different drivers & 2 different emitter resistors. 😡
Even though it is currently working, I don't trust it & want to repair properly. The Crown manual notes the C7065-3 as (MJ15004) & C7901-9 as (MJ15003). My question, are MJ15003/4's really adequate given the amp has 140v Rail to Rail? Output stage is a grounded Bridge with 3 pairs of o/p's for each half bridge. The amp is rated at 760w@8, 1160w@4 & one source states 1500w@2 ohm per channel. Yikes! that's a lot for those MJ15003/4!
Should I stick with MJ15003/4 or go to MJ15022/23 or even MJ21194/5 as many in these forums have suggested for other members repairs & projects? My apologies for the long post as I want to provide plenty of info & really appreciate any advice. FYI, I am an electronic tech, just don't repair Power amps for a living, only for myself or friends. 🙂
Crown
The SOA of the 15003/4 are quite close to the MJ15xxx and MJ211xxx transistors.
The MJ15xxx and MJ211xxx are 4MHz devices whereas the MJ15003/4 ate 2MHz.
In this crude Crown circuit I doubt there is a difference. I use all three types. They are all very expensive at about $6.50 each so cost will be the same.
There is nothing wrong with running MJ15003/4 on a 140 v rail as they are specified at 140Vceo. However Crown have 22 ohm Base-Emitter resistors which pushes the breakdown voltage close to 200 anyway (Vcbo)
Steve Mantz
Zed Audio CA
Steve Mantz
Zed Audio CA
Steve Mantz
Zed Audio CA
Wow, thee Steve Mantz! 🙂 I purchased brand new & still own 2 x Zues IV's! 😎
Thanks for the info & advice on o/p's. I generally like to use factory spec parts for repairs & not "modify" but have seen so much talk of updated modern devices, so wanted to check with those more experienced. And yes, they are expensive these days at $11 CND!😱
Ross
