Mic Preamp Gain
Good morning, l apologize for diverting your attention, please help me. I would like to know how to calculate the gain accurately of this type of preamp circuit. which resistors give the gain. I want to do some frequency response measurements. thanks regards
> which resistors do you use to determine the gain.
R9, R14,VR1, R13, R12.
Why do you think the frequency response needs measuring? (Worst-case on lows is about 8Hz; highs is very supersonic, and dead flat between.)
Mic Preamp
Thanks trying to use ARTA, will need a mic preamp with precise gain steps. User manual recommends a Monacor mpa-102, with a stepped gain, trying to build mine at a small budget. Phil Allison states that this circuit goes to 60db, how do you arrive at this with the resistors that you illustarated
Assuming infinite loop gains in both the discrete part and the op-amp, Zmic << R1 + R5, Zload >> R16 and R4/(R4 + R10) = R8/(R8 + R11), the voltage gain is:
(R12 + R13) * R4/(R4 + R10) * (1/(R2 + R6) + 1/(R9 + ((R14 * VR1)/(R14 + VR1))))
Assuming +/- 15 V supplies, you have to add about 1.2 ohm to 1/(1/(R2 + R6) + 1/(R9 + ((R14 * VR1)/(R14 + VR1)))) to correct for the effect of finite loop gain in the discrete part, so the gain then becomes
(R12 + R13) * R4/(R4 + R10) * 1/(Rcorr + 1/(1/(R2 + R6) + 1/(R9 + ((R14 * VR1)/(R14 + VR1)))))
with Rcorr ~= 1.2 ohm.
