Amp Camp Kit Parts For sale (Almost all parts you Need)
I built some upgraded Amp Camp amps and had some parts left over for a couple more amps. Because I just received a job promotion, I will have little time to finish building these last two amps. What I have for sale is:
4x 100% working Amp camp 1.6 boards (toshiba Fets and IRFP 140 mosfets)
4x Cap Multiplier PSU boards (untested but stuffed)
4x KBU8 Bridge diodes for the PSU boards
3x IRFP9140 for the PSU boards (1 more needed)
2 RCA Jacks (1 left and 1 right - one more set needed)
1x Switch On-On (one more needed)
2x XLR female panel mount iputs
1x Set of Speaker posts (one more set needed)
2x Power switches
12x Large washers for mosfets
2x IEC inlets
The main parts you need to finish the amps are the two chassis', remaining parts listed above, and the two Antek AS-2220 torroidals.
I am located in Houston, TX and selling all the parts together for $200 plus shipping.
