H heracles46 Member Joined 2021 2021-04-22 10:26 am #1 2021-04-22 10:26 am #1 Hi, All pentode tubemodels at Ltspice g3 is connected to k. The attached circuit diagram shows EF80 g3 only connected to external R and C. Does anyone have a tubemodel I can use. Any Pentode welcome. Thanks in advance. Udo Attachments EF80 Audion.pdf EF80 Audion.pdf 12 KB · Views: 163 Mooly Moderator Joined 2007 Paid Member 2021-04-22 10:28 am #2 2021-04-22 10:28 am #2 Moved to software tools. You must log in or register to reply here.
