WTS/WTT [USA - WI] Mark Audio Super Pensil Cabinets
I recently built the 12p-sized frugal horn and removed the drivers, hook up wire, and terminal cups from these cabinets. The 12p sounds great in this cabinet, it was just time to build something new and I had the room for the larger FH-type enclosure. Rather than store them (they're big), I'd like to see them go to someone who can enjoy them.
The top and baffle are a butcher block and the sides/rear are a stained plywood. There's a little checking here and there and the cabinets could use a quick sand and fresh coat of poly, but they're structurally rock solid.
You can find approximate dimensions here: http://www.frugal-phile.com/boxlib/pensils/Pensil-Series-set-100711.pdf
Would trade for tubes, amplifier parts, woodworking tools (power or hand tools), bench equipment (power supplies, etc). Asking $50 to sell. They are located near Milwaukee.
