SBAcoustics 61-NRXC with SB17NRX2C35-8
Hello, I'm intrested in building this open kit SBAcoustics-61-NRXC with newer SB acoustics woofer SB17NRX2C35-4 (main reason beacause I already have drivers🙂).
I read this article www.audioexcite.com >> Blog Archive >> SB17NRX2C35-4 vs SB17NRXC35-4 and how I understand drivers almost interchangeable but still need some tweeks. In past builded couple of kit's but never designed a crossover. So how could I figure out those tweeks ? Just try to put this crossver in some sort of crossover design software ? And also in the article is this sentence "Also, another factor to consider is that if combining the two NRX versions with the same tweeter, the drivers relative acosutical off-set is about 3-4mm larger using the new NRX2 driver compared to the old NRX driver." What is relative acosutical off-set? Information that I managed found myself was to technical to understand.
Jo0, you have missed something rather important:
SBAcoustics-61-NRXC
Troels uses the 8 ohm version of the midbass!
It's not going to be easy to adjust for that.
Two circuits here for the Mark 1 version of your driver:
Small studio monitor using SB Acoustics SB17CRC35-4 and SB29RDNC-C000-4
597877d1486564274-studio-monitor-using-sb-acoustics-sb17crc35-4-sb29rdnc-c000-4-a-sb-acoustics-eka-png
597878d1486564274-studio-monitor-using-sb-acoustics-sb17crc35-4-sb29rdnc-c000-4-a-sb-acoustics-eka-notched-jpg
4mm extra offset on the Mark 2 midbass will just tilt the lobe down a tidge. They will sound better below axis to a slight extent, but 4mm is next to nothing really. It would take a sim to sort that out.
The second circuit is probably better if the notch is accurate. Again it would be good to sim it to see how it works. But I expect either will sound alright without adjustment.
The Eka is a flat baffle. 200mm wide, 12-15L. Centred tweeter.
There's two ways to go here. Either adjust Troels' bass filter for 4 ohms ( Actually 3.1R versus 5.7R in your case) and allow for tweeter loudness with any different tweeter. This is stepped baffle, of course. The SB26ADC is well liked as it goes:
SB26ADC-C000-4 / Aluminum – Sbacoustics
The SB26TAC is 2dB louder:
SB26STAC-C000-4 / Fabric – Sbacoustics
Or you adapt the second EKA circuit for the SB17NRX2C35-4.
6″ SB17NRX2C35-4 / Norex – Sbacoustics
Your woofer has a sharpish breakup peak at 6kHz, so the notch should be placed there. Probably around 3.9uF/0.2mH/2.2R, but you can check that.
If you don't rebate your woofer, that should fix the 4mm acoustic offset change.
