Hi all, I have a Pioneer Gm 3400 which powers on but makes no audio from the speaker outputs.
The input gain board CNP2608-D had 4 badly leaking capacitors C308, C307, C305 and C305 which I replaced
but still no audio.
IC302 and IC303 have no audio on pins 5 and 6.
Any help appreciated
but still no audio.
Thank you Perry, evidently not.
It's working fine now.
Would it be OK to ground the rca inputs internally from amp ground?
Probably not. The isolation from ground is what prevents ground loops. If you use a standard head unit, it will work as expected.
