2 way: Upward firing 12inch + CD with 15inch waveguid
Hello,
I have been reading about Horns and wanted to start designing my first pair.
I see that most match the woofer size to the horn for constant directivity. I have been studying Earl Geddes designs and looking at best size compromise.
Because of design constraints I was wondering if I could use a 12inch driver pointed to the ceiling and cross over at 700 to 900 hz to a CD with a 15 inch waveguide. I would assume that I would lose low end directivity and that my directivity would start around when the CD takes over. Since I would be crossing over low would I have problems with this design?
I am planning to use a mini dsp for the crossover.
THanks for any help.
A 12" on a small baffle is almost omnidirectional at 700Hz.
Newpaton2 - your concept would probably work OK, but you'll need to find a CD/horn combo that would be happy crossing over that low. In a domestic (not PA) application this might not be too difficult as you won't be pushing the CD too hard. In fact you might benefit from "cheating" a bit. If you use a larger 1" waveguide (like the famous QSC and it's clones) you'll find it starts to lose pattern control below ~900Hz. Since your bass driver has no directivity this might make the match OK. Your alternative is to find a big horn and probably use a 1.4" CD. Maybe the Eminence Textreme CD (which is OK with crossing over pretty low.
Ok, I will keep in mind the Radian since they seem to have really good reviews. I have modified my design to create a proof of concept speaker that is much smaller and easier to expedriment with. I will use a 5.5inch midwoofer pointing upward or downwards and experiment with different waveguide sizes and crossover points. I can 3d print the waveguides and use a minidisp to simpify things with the crossover.
This build would be kind of like a linkwitz mini or pluto but instead of integrating the midwoofer to a a full range dipole configuration I will integrate it to a waveguide instead. My thinking is that even though the 5.5 midwoofer should be omni well beyond 900hz I could benefit from the constant directivity of a larger waveguide and cross over to a CD at around this frequency.
