Maplin derivative 75WRMS lateral mosfet amp.
FS: Maplin derivative 75WRMS lateral mosfet amp.
New build Maplin 75WRMS lateral mosfet power amp.
Uses Exicon laterals which cost me £20 for the pair.
Choice of TO3 or cheaper TO247 output transistors.
Requires power supply and heat sink.
Asking £29.99 plus p+p
p+p is £4.20 to UK and £12.99 to Europe and £18 to rest of world.
Nice detailed sound.
I took Maplin (Hitachi) circuit and added extra decoupling on front end. Added DC offset adjust.
Uses modern easy to find components.
Its a mono pcb.
The small heatsinks were used just to test it.
Requires 18-0-18 VAC 150VA transformer, bridge rectifier, 10000uf smoothing capacitors and heat sink for 4 ohm version.
Requires 24-0-24 VAC 150VA transformer, bridge rectifier, 10000uf smoothing capacitors. and heat sink for 8 ohm version.
It was sold about an hour ago.
I have some bare pcb's if you fancy building your own ?
