Full Bridge D-Class 2000-2500W Operation Wanted
I found many documents and examined them all. I saw he was wrong. In the comparator part, the tl072 compensation capacitors are reversed .. Ne555 150uf-10nf in the ocp part - it does not go on the line .. I pressed the PCB, then I saw the errors when I checked it. I said I'm going to make another card and I saw that they were not good. I would be glad if there is a full document as sprint layout or pdf. It must be ocp.
  • 2KFB LAY 285X90 B.pdf
  • 2KFB LAY 285X90 h2 (1).pdf
  • D2KFB - Fullbridge V.2.pdf
