Alpine MRV-t505 blown mosfets
hello ,
i need some help to try fiwing a mrvt505 amp;
sudenly stop working
open it : Q503 and Q504 are blown, all pins shorts.
so remove them, and replace
Q503 was readable : irfz44 but not Q504
Q505 and Q506 just near them are all irfz44
so i replace both with irfz44n
no shorts then
so i plug it in the car and mosfet blown again !
what can i check please ? (no other part seems burnt)
thank you
hello
here some pics
thanks for help
sorry mistake.
in fact the two residual z44 have not the same value
short is just active mosfet, after discharge got same value as new one.
but the other with positive value has not the same as new, here are the values :
red probe first, black second
1-2 : 1400 instead OL on new
1-3 1100 instead OL
2-3 : OL even after activation (new gives OL and 0 after activation)
3-1 : 1060 instead OL on new
3-2 : 515 as new one
damn, i had resoldered them.
i tried to turn it on on power supply (not good i know but so excited) : now with 8.5V 2amp limit; i ve got sound on both channel with a simple mp3 player.
can i test voltage like you tell me with fets or it is to late ?
thank you sir
The test is to prevent damaging the FETs so you test without them.
It takes just seconds to remove the FETs. Apply additional solder so that you can lay your soldering iron across all 3 terminals. When all are hot enough, pull the transistor out of the board and desolder the pads.
Have you confirmed that you don't have any shorted output transistors?
