Ground Zero GZNA 2800X PS Trouble
Received this amp with a blown PS section. Removed all IRFZ48V and replaced with STP80NF06.
Rectifiers removed, because some of them short.
Everything else looks ok.
Without recitfiers it pulls high current.
But it seems, that the Fets are not driven good.
Gate resistors are original 328Ohm,
there are no pull down resistors.
I have on each bank a 10 Ohm resistor at the source, with a cap connected to drain.
Yes, drivers are ok.. I changed the resistors to 39Ohm, now its ok.. without rectifier 0,4Amps current.
First picture is gate, second drain.
