dd audio 3a
all powersupply fets where burnt out .i check the gate voltage is 3.96 volts ..i put in the fets anyway and it heats up in 2 seconds ..i checked the transistors connected to the gate resistors and they are good ..i even changed the powersupply card ..no luck any ideas ??😕
the main board
the main board
